Webbo15
Hi everyone - I am a new boy here, having just purchased an '07 C180. Have been doing usual checks when acquiring a new vehicle and the only concern at present is the power steering fluid level. When I remove the dipstick fluid is only just visible at the bottom. There are a series of marks on the stick from the bottom and extending upwards for approximately 1 cm. Am I correct in assuming the level should be to the uppermost mark? Also can someone advise the correct fluid to use - I do have some Dexron 3 but unsure if that would be suitable.
