You'll need quite an assortment of different shaped spanners,some of those pump bolts are awkward. I actually used one of those chain type oil filter wrenches to hold the pump pulley bolts while undoing the large nut that screws onto the pump (make sure you've got a spanner to fit that nut BEFORE you start) Also, there is a small hose that fits 'tween pump & thermo housing, get a new one, or regret it later ! Make sure your drive belt is good while you're at it.
