merc180k
- May 31, 2007
- C180K Avantgarde SE Sport
Needing a bit of help from any c class owners with the sports kit. I'm replacing the discs on the front and need to pass the measurements on but have a problem.....
It's pitch black outside , it's peeing down so don't fancy taking the wheel off and spending any length of time getting soaked , and my quick measurements don't seem to fit the sizes that I have found for the discs on various web site as a double check.
As a triple check can anyone confirm the various sizes I'll need?? I have the drilled & vented discs on the front that came with the sports package. Are these measurements right?? If so my measurements are quite out!!!
I can check again tomorrow but thought someone on here might know offhand.
Simon
Having noticed another post for a C200k with sports kit the disc for that are 288mm diameter. Woill mine be the same - can't see them being any bigger for a less powerful car like mine? If so my quick measurements are not that far off.
Dimensions
Diameter = 345mm; Thickness of disc = 30mm; C = 28mm
Disc depth from hub edge to back = 46.5mm; E = -mm; Holes (F) = 5.
Vented discs.
Vented discs.
Simon
