C200 heater woes.
Bladerunner
Tamworth,Staffs
C200
My '98 C200 has recently developed a strange squeaky / squealy sound from the heater-blower which I suppose, is the start of a bigger problem. I have seen a well photographed article by "Shude" on heater motor removal. If I removed my motor, any suggestions as to what I should look for / clean / lubricate, or does it look like I need a new unit ? :confused:
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
As it is Autumn, have you checked that there are no leaves in the air inlets. This may not be as strange as it sounds, as I had that problem on my 190E.:confused: :confused:
OP
OP
B
Bladerunner
Tamworth,Staffs
C200
Thanks Brian, I will check that first. Incidently, how do you get your photo(s) at the end of your message ?
Brian WH
East Midlands
For signature & Other Photos see
Photos
For signature - go to user control panel-edit profile, under signatures add wording and http link to photo, but it must be no bigger than 300 x 125
