C200 W202 Misfire.
smiff
C200
Help folks - I'm confused.
I've got a misfire at low revs which happens when the revs go down to low levels as I brake for a corner. The engine refuses to accelerate away from the corner, then misfires, then pulls OK.
Help????
(MAS problem??) :confused:
watsone91
scotland
c250tdi/e200
coul be something simple so start simple ignition leads ? plugs ? rotor ?fuel filter?
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
The car wont have leads, distributor, rotor or cap. The MB's use a semi-direct ignition system. Could be the plugs but if it hesitates then is OK it makes you think something electrical or ECU related causing a blip.
RAV
C220 1995
Is the problem conisistent or intermittent? I saw a similar problem on my father's W202 c220 (petrol) where the symptoms were intermittent. They did nto always occur when braking but also when starting up at times.
It turned out to be an ECU problem. What mileage is on the car?
