Do you get the click from the pump when you use the remote fob lock button or unlock button or boot button?
I can hear a click each time I press the lock or unlock button on the remote. The boot button is a bit temperamental - it will click the first time and then will not until a few times later.
Do you get the click from the pump when you use the pull up boot switch beside the mirror adjuster switch?
Same as the remote button, it will click when I first get in and try but then won't for a bit, but will a later on if I wait for a while.
Cheers,
Andy
Cheers,
Andy
