C2001000 The supply voltage of control module "N30/4(Electronic Stability Program control module) " is too high/(overvoltage)
Pedrostar88
Wick
C Class
I’ve got the above message on my W204, anyone had any similar problems? I’ve also got both rear speed sensors showing no values when hooked up and driving at low speed. I swapped both rear wheel speed sensors but no joy. I spoke to iCarsoft and he thought it could be the ABS control module, I got a second hand one from eBay with an identical part number so was gonna try and change it out to see if that makes a difference. I live very remotely and my nearest Mercedes garage is 150 miles away and no garage close by has the star diagnostic machine.
I had the same issue with a speed sensor on the front a couple of years ago. I changed it out and was fine.
I remember I had the same message but it only had ABS inoperative and not the EBD inoperative part, could that mean it’s the control module.
Apologise for the long winded post.
