C200K engine warning light!!
uk174
West midlands
,190cosworth,420 sl,
Have had this c200k 2002 model for three days and though have hardly driven it as it was bought for resale,have noticed that engine management light is now on. took to a local indy who said that fault codes were for a air mass sensor and for oxygen sensors.
have changed air mass sensor but still getting engine management light on and now when i check with diagnostic machine am getting a p0138 code...o2 sensor bank 1 . The car in it self drives well,power is ok,but am now a little worried as have looked on forum and noticed that these c200k engines are a little prone to faults.People have mentioned oil getting into loom and air mass hence light on.By the way the air mass i put in was an 80pound job from car spares .
Is there anything that i can do as some have suggested that fault lies in wrong air mass choice and others that to fix this i need to clean intercooler,breather pipes, . Very confused as car runs well but engine light a big put off.
OP
OP
U
uk174
West midlands
Thanx for the reply,but for fear of sounding ignorant what is the best way os doing that?
Bristol
Mercedes-Benz C320CDI & SLR McLaren Coupe
Disconnect the plug at the Cam Magnet and check there first.
Disconnect the O2 Sensor and check for oil there too. Then get a multimeter and check the internal resistance through it. Should be 9 ohms. Anything less then the sensor is goosed.
OP
OP
U
uk174
West midlands
many thanks and will let you know how i get on .
OP
OP
U
uk174
West midlands
by the way steve,if there is a little oil in the cam magnet iand o2 sensor is an o2 sensor change sufficient to switch off light or is more work required.
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
You idealy need a new engine wiring loom and a blocker loom to stop it happening again. The oil in the loom will contaminate new parts if not replaced.
nigel cross
Surrey
W164 ML350 Audi S4
Sounds like ££££££
