Hi All
I have searched high and low through the forums on more than this site but dont seem to be able to find my answer. So any help would be much appreciated.
The car is a c class 200 Komp auto on a 02 plate 74k miles. The car started to run a little rough around november. It was well over its B service so i had that done first. The garage said the car threw up some MAF codes but they seemed to have reset. Around 2 days later these where back. I had the MAF replaced along with the Lambada sensor. The car was ok for a few days but Maf codes returned. The sensor was replaced for the proper Merc one at that point with no charge.
The car still runs strange, There is no engine warning lights on, The car runs fine on tick over. The idle speed seems to be fine. The problems seem to be when the car goes into drive. The revs drop down and then rise sharply and the car seems to want to drive off even with the breaks on. This happens at junctions and lights when the revs are low. The throttle pick up is sluggish when moving away from lights but then picks up after a few seconds. The symptoms seem to be worse in the cold but this could be my imagination.
Any help would be much appreciated. I love my merc and would like to keep it
Scott
Scott
