Hi, Ive a 03 reg c200 kompressor auto. After driving all day yesterday I stopped to get out of the car for about 1 minute to go to a bank machine. When I got back into the car and turned the key the car would not start. I tried turning the key again and again nothing happened. No noise, no clicks just nothing.
I got out of the car, closed it with the fob and then reopened and tried it again with the same result. When I turn the key to position 1 everything is ok but when I turn it to position 2 one of two things happen. Sometimes the mileage screen goes blank and there is a clicking noise and the SRS light on the centre console comes on and off with the clicks (this is before I try to start). Or sometimes all all the dash lights come on and everything seems normal then why a try to start the mileage screen again goes blank and there is no noise. Sometimes I get a quick flash of a couple of errors. One is "srs failure" or something similar and the other says something like "brake fluid leak". I checked the brake fluid reservoir and it is fine. When I take the key out and try again then it says no malfunction.
I thought it was maybe the battery but I tried to start it today with a set of jump leads and that made no difference. Same thing happening. Turn the key to start and just nothing.
Any ideas what could be the problem ?Starter, solenoid, relay, fuse maybe or something worse like the engine management system or some sort of electrical failure . Just seems as if the car wont allow itself to start.
I'm really worried and hope someone could shed some light on the matter. Many thanks to anyone who can help.
