C207 Parking Break overhaul
MrGundam
Hampshire
2012 C207 E350Cdi
Ok so mid job and can’t figure how to detach the parking brake cable from the lever.
I have a replacement in my MB kit but seems impossible to get old one off without further dismantling.
Jigglyjohnson
Uk
C220cdi
The cable needs to be completely slackened off and the shackle opens up and the pins can then be removed allowing the metal part to be removed from the cable
OP
OP
MrGundam
MrGundam
Hampshire
2012 C207 E350Cdi
Ok managed to manhandle it off, was seized!
seems the springs are different for my replacement, which way does the hump go? Towards centre or out?
OneForTheRoad
uk.
2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Keep the end hooks the same way round as the original spring. Not sure about that kink tbh.
Petrol Pete
Petrol stations ...everywhere
C55 AMG Wagon
The arch in the spring looks like it is there to clear the teeth on the adjuster. Does your car have the 'trapdoor' below the rear seat squab to access the tensioner where the handbrake cable splits to the rear wheels ?
OP
OP
MrGundam
MrGundam
Hampshire
2012 C207 E350Cdi
Seems most guides have straight springs. The spring is not the adjuster end, and the adjuster is only accessible via wheel bolt hole on mine.
Petrol Pete
C55 AMG Wagon
This image would suggest you are correct , and looking at the 'Kinked' spring you have the length looks good , so as long as the humped bit does not interfere with any other part of the brake I would just fit it as you see best.
OP
OP
MrGundam
MrGundam
Hampshire
2012 C207 E350Cdi
All sorted, thanks for this help everyone. Not a bad job overall but always a few bits blocking bolts etc.
Old discs were well worn and I imagine original covering over 100k miles.
Parking brake fixings were seized firm so had to free up the brake cable lever to allow enough movement to remove.
All now replaced with MB Disc's, Pad's and Parking Brake kits.
For anyone else doing this it seems the now curved spring (111) sits with curve facing inward:
andy27168
Southampton
65 Plate E350 CDI Convertible, 2006 CLS 55 AMG, 1997 C230K, 1999 C43/55 AMG
Hi
Did you need to adjust the cable? I need to look at mine hoping to just adjust the shoes and not have to touch the cable adjustment.
OP
OP
MrGundam
MrGundam
Hampshire
2012 C207 E350Cdi
Hi
I adjusted the spindle until it gripped disc and then backed off a bit. Didn't adjust the cable anywhere else.
The added thickness took up any slack. Still didn't cure my slow/sticky hand break issue though.
