Morning all newbie to the Mercedes Scene here,
After years of driving Japanese Rocket ships i took the plunge into the realms of comfort and luxury and now have a 2003 CLK320(Petrol) which is proving to be a pain in the butt, everything is fine in regards to running etc until i hit between 70 and 80mph under gentle acceleration and the engine warning light comes on and the engine goes into limp home mode. If i accelerate hard then the problem doesn't occur!!
I've plugged it into a Code Reader to see what codes are stored and it shows P0300, P0301-2-4-5-6 etc. Only number 3 pot doesn't show the error code. The leads and plugs have been changed to eliminate faults that end. I know the codes show as random misfires and i suspect that at 109000 miles the coils may need changing but cannot see why they would only fail under gentle acceleration and not when flooring it.
The MAF has also been changed along with the fuel filter for OEM parts so don't think its fuel related leading to the ECU shutting down the affected cylinders.
I'm lost as to what to try next so any input or help would be appreciated. I am a qualified mechanic for both cars and bikes but this one has me puzzled.
Now its back to my man cave and the change over of the rear upper control arms to stop the damn squeaks.
Cheers
Cheers
