Finnborg-Braga
- Oct 12, 2015
- C220d W205 estate
I have a C220d, W205, Nov 2015. The alternator appears to be running all the time - when the engine is running the voltage at the cigarette lighter socket is 14+ volts, dropping to 12+ when the engine is stopped.
I was under the impression that, once over re-charging the battery after a cold start etc, and assuming no major electrical consumers such as headlights are on, the alternator should only cut in when the engine is on overrun, and be off most of the time otherwise. Is this correct?
