Hi All from a new member! I did have the intermittent limp mode problem with my c220 cdi which after turning off and on again cured it and it then would run fine for a good few days then would suddenly go into limp mode again (never had any lights appear on the dash though). I was driving home last night and again went into limp mode so i pulled up, did the stop start routine but it didnt come out of limp mode just tootled along at a max of about 40 with very slight surging motion, but with no acceleration.
I called at my local garage and we took the pipe off the end of the turbo as he thought it might be turbo related to see if there was play in the shaft only to find that the nut on the end of the shaft was loose which meant the shaft was spinning but the blades werent.
There doesnt appear to be any damage to the inside of the turbo and turns smoothly other than the loose end nut it seems ok. My question would be(apologies if it is a daft one) but now this nut is loose do i need a new turbo as the nut is designed to be crimped tight and has come loose for a reason or is it possible to just nip it back up and it should be fine. Not easy to nip tight as cant really jam a screwdriver in the blades to stop it turning lol.
Thx in advance for any help or suggestions.
Andy
Andy
