C220 CDI - Automatic 2005
Discussion in 'Engine' started by Kevzdodd, Jul 14, 2017.
  1. Kevzdodd
    Kevzdodd New Member
    6
    Jul 14, 2017
    Car:
    C220 CDI 2005 Auto
    I've purchased a 2005 C220 CDI Automatic. The car itself is brilliant but I've been having a few issues with it, within the two days I've had it.
    I believe this model is a 5 gear automatic gearbox. Whenever I'm in drive and use the manual gear selections it only goes upto 4 gears - does this mean it has only got 4 forward gears and it means the 5th would be the reverse?
    Also, I seem to be getting an average of 34mpg driving very very steadily, is this normal for this car? I know I'm having problems so this could be contributing to it.
  2. exvolvoman
    exvolvoman Hardcore MB Enthusiast
    224
    Jan 25, 2017
    Mid Wales
    Car:
    2004 C180k Estate & Volvo V70 T5
    I've got a 2004 c180k, same gearbox I think (?) when using the manual shift the display only goes up to 4 then into D which I presume is 5th and uses all 5 gears.
    I assume this is normal, some of the experts here will be able to advise.
  3. whitenemesis
    whitenemesis MB Club Veteran
    16,320
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2019
    Unless you have the 'M' mode on the 'box selector button using the manual gear selection (as you put it) only serves to restrict the gear range. So with 3 showing in the cluster the box will only shift automatically from 1st up to 3rd and no further. It's meant to stop the 'box hunting for gears, especially in hilly regions
    For true manual selection you need the 'M' mode, in which case it will show the gear selected in the cluster and only automatically shift up at the red line, or if you lift off. Only AMG models hold the gear until the driver makes the change
  4. l5foye
    l5foye Hardcore MB Enthusiast
    813
    Jun 16, 2003
    N.Ireland
    Car:
    ML 300CDI
    A friend has a car similiar to your's -same age, 200k miles. At an average of 48mph, he is getting 60+ miles to the gallon. If you are only getting 34mpg, something is wrong.
  5. OP
    OP
    Kevzdodd
    Kevzdodd New Member
    6
    Jul 14, 2017
    Car:
    C220 CDI 2005 Auto
    Thank you.
    Must be something wrong with it then. I'm getting no more than 34 on average without flooring it. I've had the oil light and the esp light come on. Now it's got a loss of power and struggles to get to 40.
  6. JDL60
    JDL60 Hardcore MB Enthusiast
    1,041
    Apr 17, 2015
    Wirral
    Car:
    BMW i8
    Yip, it's gone into limp mode so something is indeed wrong. Since you've only had it a few days, if you got it from a garage or dealer get it back there, otherwise to your nearest Indy to get a Star diagnostic to find out whats afoot...
  7. OP
    OP
    Kevzdodd
    Kevzdodd New Member
    6
    Jul 14, 2017
    Car:
    C220 CDI 2005 Auto
    That's a lot of miles! Must be a reliable car then....I'm hoping the gearbox doesn't go on me. I've heard older gearboxes aren't very reliable.
  8. whitenemesis
    16,320
    May 7, 2007
    Car:
    Gearboxes are strong, it's the electro-plate with speed sensors, that fail..
  9. Stratman
    Stratman Hardcore MB Enthusiast
    4,635
    Jun 15, 2003
    Sunbury
    Car:
    W203 C200 CDI '04Estate
    Check the C/S button next to the gear lever. If it's set to C the car will pull away in 2nd gear so you'll only count three changes.
    In S it should start in first but the transmission 'learns' your driving style, if you've been driving gently it may still start in 2nd on a light throttle.
    Drive it like you stole it for a bit, then do a spirited standing start. You should be able to detect four gearchanges.
  10. whitenemesis
    16,320
    May 7, 2007
    Car:
    IME the 'box always starts in 1st when S is selected, irrespective of learnt adaptions. With C selected, the 'box will start in 1st when the engine and CATs are cold and if given more than 60% throttle, otherwise it's a 2nd gear start.
  11. mick5
    mick5 Active Member
    79
    Jul 11, 2010
    London
    Car:
    W213
    My car is 2005 C 220d and has 110k i get average 59 to 61 mpg on motorway in city i get 38 to 42mpg.
  12. ampwhu
    ampwhu Active Member
    91
    Aug 25, 2014
    New Malden, Surrey
    Car:
    W203 200CDI
    mine is on 151K and drives perfect. i'm getting around 45-50mpg.
    check your thermostat in the engine. does the temp get to 90c in around 5-10 mins from start? if not, then this is where to start.
  13. OP
    OP
    Kevzdodd
    Kevzdodd New Member
    6
    Jul 14, 2017
    Car:
    C220 CDI 2005 Auto
    The thermo doesn't ever touch 60, could this be the reason? Does this affect the fuel if the thermostat is faulty?
    Also, do you have the c200 or the c220???
  14. Stratman
    4,635
    Jun 15, 2003
    Sunbury
    Car:
    The thermostat will most certainly affect fuel consumption, and your's is faulty.
  15. ampwhu
    91
    Aug 25, 2014
    New Malden, Surrey
    Car:
    W203 200CDI
    its the same engine. 646 engine.
    you've found your problem. its the thermostat then. the car thinks its always warming up so will use more gas.
    don't buy cheap crap from ebay. walk into a merc dealer and buy the proper part. its around £40. don't forget a gasket.
  16. OP
    OP
    Kevzdodd
    Kevzdodd New Member
    6
    Jul 14, 2017
    Car:
    C220 CDI 2005 Auto
    Sorry it does hit 60, this is a photo taken this morning. Does it still need changing?
    Attached the photo.
  17. markjay
    markjay MB Club Veteran
    24,297
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    Looks like the thermostat to me.... it should reach at least 80.
  18. ampwhu
    91
    Aug 25, 2014
    New Malden, Surrey
    Car:
    W203 200CDI
    id agree, thermostat it is. these are the part numbers from my invoice when I did it.
    thermostat 6462001115
    gasket 6112030380
    its not hard but remove the oil filter housing cover for better access.
  19. rf065
    rf065 Hardcore MB Enthusiast
    3,925
    Jun 8, 2007
    Grossbritannien
    Car:
    SLC300 - C250d Estate 4 Matic & Z900rs
    Not so, on my 2005 with 3 showing in the cluster the box will shift to 4th if you do not change as the revs rise near to the red line. The gear range is never restricted when changing manually and will always change up itself if not done manually just before the red line.
    Russ
  20. whitenemesis
    16,320
    May 7, 2007
    Car:
    Correct, only to prevent over-revving the engine. As I posted, unless you have the 'M' button, "manually" changing gears only serves to restrict the gear range. The 'box still operates automatically within the restricted range. True manual shifting is only possible with the 'M' button. Even then there are subtle differences between 'M' modes in AMG models and non-AMG models.
Share This Page
