C220 cdi (W203) Won't rev past 3k in drive.
xp2500
Surrey, UK
2002 C class coupe w203
Hi guys....
My car just started to go into its strange limp mode.
In park or neutral I can rev the car at standstill up to red line.
When my MAF sensor became faulty previously I was unable to do this.
Now it is sluggish to accelerate and wont rev past 3k.
Apart from STAR diagnostics does anyone have any advise / suggestions?
How long ago did you change your MAF sensor and did you purchase an original or a cheap version?
STAR is the best way forward tbh
It was a piersburg unit 55 or so...
I changed it when I bought the car in september 2012 and realised it was pretty slow to accelerate.
I know STAR would be the best , but Im just cheap .... I have a friend with x-launch and snap on scan tool that I will use on it later in the week perhaps but its a bit of a journey to get there.
Thanks Dieselman! Good to know that your always about when I need help! I am going to get to googling how to check that out!
Also anyone got an opinion as to why it would Rev to redline in neutral or park ?
Ok! This issue is solved now
I put it on a snap on computer and got the following code :
So after looking this up on auto data it was suggesting an issue with the sensor that is located on the right of the engine going down from the EGR.
When I looked at it I discovered that a wire at the back of the connector was damaged ...
This is the cause of my low power :wallbash:
This is where the sensor was
So I went to a scrap yard to try and find the connector but they didn't have any diesel mercedes :(
So instead I pulled out the plastic surround from the wire end of the connector.
Then I separated the grey plastic cover to give access to remove the damaged connector.
After it was removed it was just a case of soldering a new wire in place and splicing it to the loom.
After this was done happy days :D
