saor99
Hi, I`ve been trawling through some old posts in order to find the reasons/salutions to a problem with air bubbles in my 1996 c220 auto diesel. The best that I found, with pictures, was by BrianA in 2007, and as I would like to do similar I was wondering, what happened?
I`ve bought the fuel lines, to cure the air bubble prob, and when they are fitted I hope they will work......I`m going to remove the manifold so have ordered the o-rings, and try and fix a leak in the fuel pump. This is a problem as I cant , at the moment, just get the crush washers and o-rings without buying a whole service kit (????) any ideas?
All the photos I`ve seen about removing these only shows a 5 cylinder setup, whereas mine is a 4 (see photos).
Any advice before I start?
