sfc
- Jun 15, 2016
- c220
is there a way of switching on sports mode on a c220 amg sport + coupe 2012 ? ive looked for a button but nothing can be found, someone told me i need to adjust settings on steering wheel ??
I thought the sport varients had different brakes, suspension or exhaust, don't think there is a sport button.
Russ
sfc said:no button there just return switch and storage, this car is manual gears if that makes a difference ? yes it also has eco button, thanks for help , will look up tcu reset
Oh if it's not automatic then the reset can't be done, I thought all w204 sports had that button. It's bottom right of the middle section
Or better still get a C63? What a pointless and completely unhelpful response to the OP's question. These things are all relative and despite my dislike of diesels I'm certain that you can have far more of a buzz in a manual C220CDi that's properly set up than you can in say a VW Up Auto. The power to weight ratio of the OP's car is far better than my second car, a Jaguar Mk7M which was great fun to drive (and a model that won the 1956 Monte Carlo rally). As for suggesting that the performance of a 350cdi is "blistering", I have to admire your sense of humour.Yugguy said:You will never get a buzz from 170bhp in a 2 tonne car. Get a 350cdi or accept it for what it is - brisk but not blistering.
Look to your left in the middle section, few inches from the command dial towards the back of the car is the sport mode button which switches it from Comfort, Sport and Manual
Don't expect it to be amazing, it changes the gear changing throughout the revs, holds onto the gear longer and doesn't pull off in third gear (IIRC)
As its new to you also try a TCU reset, google it and you'll see how to do it
But as the Fox pointed out, things have moved on. My 2012 C350 petrol with the M276 engine has 306 lively horses available and is in the same tax band as the CDI. Fuel consumption is slightly heavier than the diesel version (except for short journeys from cold where it's probably better) but with the higher cost of diesel fuel the difference in fuel costs becomes much closer. I don't have to worry about DPFs nor disturbing neighbours with rattles at start up.Yugguy said:Your inference is incorrect. Given that the op chose a diesel originally to recommend a 350cdi which has speed but still decent mpg makes far more sense than a 63. Having been in an e350 cdi it's top of my list for a next car. I would not choose a big petrol now, I begrudge the fuel and tax costs.
derektrotter said:Does the TCU reset also work for W212's? I have a E250 and not sure if I'm used to it now but doesn't feel as quick anymore as when I first purchased, sports mode helps but MPG definitely takes a dip.
