hollyhocks
- Apr 19, 2010
Hi our 2002 C220 CDI seems to have lost about 10-15% of its average miles to the gallon, any ideas anyone.
joecash said:change the thermostat - not that expensive - will pay for itself very quickly in fuel saved common problem - quite a few threads on here
Hi thanks for all your comments, why do you need to change both the thermostat and housing?
The stat will make little or no difference on the mpg...
A failed stat will most definitely reduce fuel economy a diesel runs best when the engine is hot so a stat not allowing it to reach the correct operating temp will effect your mpg.
