DopeyDave92
Hi all, I'm working on a friend's 05 plate C220d. I've repaired a number of faults and it's been running like new for weeks with no issues whatsoever. My mate then rings me the other day to say he's had to get recovered home as it "doesn't do anything when you try to start the car".
Green flag guy said starter tests fine and I later notice fuse 52 (15amp) is blown. I read online that Mercedes recommend changing to 20amp for the C220d and so thats what I did. Car was starting like it's brand new again (barely ever cranks more than twice before firing) and starter does seem healthy. I thought randomly blown fuse and called it a day, but the car has other ideas as next day I get a call from my friend because it's doing again only now it's blowing fuses straight away.
I came over today and I've been feeling round pretty much everything with a multimeter but I can't seem to find anything loose or shorted. Doesn't make a difference whether we use 15, 20 or 25 amp fuse, sometimes it blows straight away but others we can start it 20 times on any size fuse with no issues, can't seem to find a pattern. One time it seemed to be caused by the blowers, another it seemed to be caused by one of the cables in the ECU/SAM housing, and once it even seemed to be caused by a faulty relay but checking these things shows no fault.
I did think starter for a while but it seems very strong and following a good service a few weeks back it's been starting like a brand new car, at least until this issue. When the fuse doesn't blow it's probably the best starting >3year old car I've ever seen. At this point I'm leaning towards faulty SAM, which does make sense as his ECU needed replacing a couple of years ago but I have no idea whether that was due to liquid damage or broken pins...
I don't have a diagnostics tool that can test or reprogram a SAM so short of going over the PCB with a multimeter I can't think of any way to test it. As far as we can tell there are no other electrical issues other than 1 of the indicators on the mirror blinks fast and theres a clicking noise as the blower starts up.
What I'm wondering is if anyone can shed some light on what may be happening here, or direct me to any common faults I may be able to check. Any help will be appreciated. Thank you.
