My c230k has a erratic idle when coming to a stop.
It goes to almost zero and after a few sec goes back up to nrm. Sometimes the engine dies altogether.
Pain in the *** when at junctions.
The c230k engine is basically indestructible, it's highly reinforced compared to the NA 4 cylinder engines and apart from cracking the odd exhaust manifold it should be very reliable! I have heard of the mass airflow sensor causing problems like the one you describe, it could also be bad fuel or the ecu going insane.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
