memyselfandi
- Dec 5, 2005
Hi
I have a C230K Coupe 2002. It has recently started to judder when you are crawling along in a traffic jam in drive. If you take your foot off the brake and let it just gently pull forward the car starts juddering. If you then put your foot down on the gas it goes away, It only seems to do it when crawling. I also noticed that i recieved a check battery/alternator after engaging reverse on two occasions. On the last occasion it then said "undervoltage, switch off ....**?/x" (something or other).
Can anyone help before I take it to the Garage?
Regards
MeMyselfandI
Regards
MeMyselfandI
