The car is a W202 C230K manual. It recently needed a new head gasket at 228,000, because of oil leaking into the water, there was no leak from any of the cylinders.
Now there is an oil leak. The oil is running down the right side of the block and appears from behind the bracket which holds the supercharger and alternator. I can't see where it originates because there is too much stuff in the way.
It does not seem to be leaking from the cam cover, so the question is, what can be leaking oil on that side of the engine, besides the head gasket?
