C240 Mas
c240yaz
Can you Tech or Indie guys confirm if this is the MAS on a 203 C240 V6 ?
Have marked each pic with a red arrow, where I think it is.
I have searched the history threads for info, but all seem to be on the C240 Sport, which appears to be a different engine set up entirely.
If so, What items need to be removed to give access to removing the MAS sender unit. ie, any hoses need to come off, or just remove the torx screws to remove the MAS ? Is it a difficult job to do ?
OP
OP
C
c240yaz
Its the round thing just to the left of the arrow in the middle picture, with the grill on top
is it necessarry to remove the whole unit, round thing, or can the sender unit be removed on it's own, by the 2 torx screws . For cleaning ? The arrowed part is the sender unit ?
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
Depends on how adept you are/ how accessible it is. I probably think its best to remove the whole unit to check for gross contamination of the inlet tract since if its dirty any replaced/cleaned element might rapidly get contaminated again. It will be held in with the 2 screws as you suggest. you will have seen this? http://mbclub.co.uk/forums/showthread.php?t=26300
Bazzle
Melbourne, Australia
SLK230 1998 auto, 2006 W169 A200 Sport
Yes, undo the 2 torx and wiggle it out.
You will see how contaminated it is . Sometimes a clean is all thats needed.
Bazzle
OP
OP
C
c240yaz
Grober, yes, I have seen this excellent "How To", just that mine seems to be in a more awkward location and I wanted to be sure that I am removing the correct part.
Took the car on the motorway yesterday, first time in a few weeks and noticed a distinct loss of acceleration on kick down. I have new plugs in the post, but was wondering if I should clean / change the MAS also.
OP
OP
C
c240yaz
Bazzle
Bazzle, Thanks. I will have another look at this at the weekend. Knowing my luck and poor eyesight, I will probably drop the torx screws and lose one somewhere !!:bannana:
And here is a pic of my car...
Bazzle
I toss the Torx screws and replace with standard self tappers.
Phillips head.
Bazzle
OP
OP
C
c240yaz
What size of thread
