C250 CDI W204 DPF/Limp Mode
Add2
West Yorkshire
C250
Hi there,
I have a W204 C250 CDI Auto with a potential blocked DPF with EML on, as well as Limp Mode.
Initially had an Intake Air System Leak (P2462), as well as P2463 - Diesel Particulate Filter Restriction - Soot Accumulation..
Garage (non-Merc) fitted a new intake hose from the dealer, cleaned the DPF and reset fault codes, then advised I take it on a long motorway run with revs circa 2500-3000. I've done this several times with no effect (EML also back on and showing P2463).
Ever since, the car will not rev/accelerate above 3000 RPM, no power/kickdown/use of manual mode so assume it's in Limp Mode.
I've read it could be the DPF sensor/MAF etc. so was wondering if anyone could recommend a specialist in Leeds/West Yorkshire with Star to get a better idea?
Or is there anyone on here that has access to Star that can force a regen / or recommend the best route to take?
I believe iCarsoft MB V2.0 can also force a regen but not sure what allowance it has for soot levels before it does so.
There is of course the DPF removal route which I don't want to go down, but has anyone got any experience of doing so on this particular engine alongside a Stage 1 Re-map?
Gazwould
Everywhere
S204 C250 CDI AMG Sport
Cleaned dpf then take it for a high rpm long drive , doesn't make sense , it's clean !
I'd do the dpf pressure sensor next as they're rife and have had several part revisions .
What concerns you about dpf removal ?
OneForTheRoad
uk.
2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
as above - change the sensor and use icarsoft to adapt it . otherwise it wont fix the issue.
geoffus
Burbage
E250 AMG Sport Convertible, B200, Yamaha YZF R1.
Did the garage remove the DPF to clean it, can it be cleaned properly without removal?
Gazwould
Everywhere
Proper cleans are with dpf off the exhaust .
