C250 Cdi w204 Reliability?????
Woody1984
Portsmouth
C250 cdi AMG Premium Plus Estate.
Hi
I have a 2014 c250 cdi amg w204 estate Which I’ve owned for a few months ..So far so good I’m pleased to say !
but what gremlins/issues can I expect to pop up and at roughly what mileage later on down the road ? Is this particular Model generally pretty solid ?
Obviously this post is aimed at those with the same engine etc ? Any feedback much appreciated !
Chris
OneForTheRoad
uk.
2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
I had dpf issues at 69k . Other than that nothing. Keep the engine oil good and if you have it . Doubt you have . Turn off stop start.
OneForTheRoad
uk.
Can’t you pull a fuse on those to stop the stop/start activating ?
Yes . I pulled it on the e350 and got message on dash " auxiliary battery malfunction" so stuck it back in. The c250 was no bother ?
W1ghty
Sunny Essex
E320cdi and CLK200
Hi
Chris
You have a good MB independent down there , PCS at Horndean
OP
OP
W
Woody1984
Portsmouth
I agree a good fully synthetic oil is an absolute must in these engines particularly during the cold winter months.. DPF issues @ 69 k = ouch !! I’m guessing that’s because of mainly short journeys?
ive just started using redex diesel cleaner every so often . She’s got a full service history , only thing missing I believe is the ATF flush which if I’m right is every 77,500 miles or 5 years whichever comes sooner 👍
OneForTheRoad
uk.
Its 77,500 for the nag2+ gearbox.
Yes probably 7 miles to work 9 miles back.
OP
OP
W
Woody1984
Portsmouth
yes it’s the 7g plus box.
and mine does have the Eco stop/start but I knock this off around town I don’t like the idea of the engine cutting out then back on all the time ! Can’t be good surely ?! Got her booked In this week for a transmission service and oil / filter change with a good local Indy .. £325 inc vat 👍
OneForTheRoad
uk.
£220 here. Its grim up north.
The stop start is said to cause the onset of timing chain issues due to the oil leaking from the tensioner each time the engine turns off.
Gazwould
Everywhere
S204 C250 CDI AMG Sport
Why not choose an oil that is better for the dpf and protection of two turbos etc .
OP
OP
W
Woody1984
Portsmouth
What do you recommend?
like I said I’m using redex diesel cleaner occasionally & currently filling her up using shell V POWER diesel .. she’s definitely purring a lot better now 👍
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
1. Like all modern Diesel engines there are some potential pitfalls, but I am not personally familiar with the OM561 engine so please follow member's advice.
2. W204 cars can develop a knock from the front suspension at parking speed.
3. If your car doesn't do frequent motorway journeys, then using premium fuels can help prevent DPF issues. Also using oil with the correct MB Spec Sheet is important. But ultimately it may be difficult to avoid DPF issues altogether if your annual mileage is low and comprises mostly of short journeys.
OP
OP
W
Woody1984
Portsmouth
I agree .. petrol cars Ideal for city driving .. diesel are suited for long distance journeys 👍 should be common knowledge but it’s surprising how many diesel car owners fall victim to this thinking they can get away with short journeys in a diesel on a regular basis then almost certainly end up with a clogged DPF Resulting in an expensive visit to the mechanic .. decent oil & regular servicing a big must !
alecmascot
North East UK
C220 CDI 57 plate
And don't forget the rear subframe rusting away.......and the springs breaking...and the brake pipes corroding.....and the water pumps packing up.
OK. It's a bad day.
W1ghty
Sunny Essex
E320cdi and CLK200
OK. It's a bad day.
Look on the bright side , they might never happen :)
OP
OP
W
Woody1984
Portsmouth
Apart from the subframe I have had all of those, but mine is twice the age.
[/QUOTE
Maybe that’s the point , mines newer so less wear on parts ! Age / miles we talking ?
more to the point if you can’t afford the up keep of a Mercedes then maybe you Shouldn’t own one ..
OneForTheRoad
uk.
Maybe he paid to have issues fixed and lives in a 20 bed mansion ??
