C250 Combustion Chamber
j_mark_walker
Can anyone tell me if the C250 engine is Direct or Indirect Injection?
Also, does anyone know what material the cylinderhead is made from - Cast Iron, or Aluminium?
I'm considering running one on vegetable oil.
Mark
  • Like
Reactions: PJH
These engines are indirect injection, the cyl head is ally & they are supposed to be very good for running on chip fat due to the fact they have an inline fuel pump. hope that helps
  • Like
Reactions: PJH
Ditto.
Also the pre combustion chamber has a hot spot to better evaporate any fuel droplets.
These engines will probably be ok to run on neat veg oil but you should really install a block heater to get the temperature upto 70c before starting to ensure no polymarisation of the oil.
The pre-chamber is similar to a whirl chamber design but with a baffle surface in the spray area to cause the fuel to further atomise and mix with the air better. This gives a more complete burn and more power with less smoke and lower emissions.
