C250JRH
- Feb 25, 2014
- Mercedes C250 Sport
I just received advisories for both front wheel bearings on my s204 at the MOT.
Due to some outer edge tyre wear, I had checked the end float on the n/s wheel bearing a month or so ago prior to taking the car for a 4 wheel alignment (where it didn't need adjusting, advised to increase front tyre pressure and use a tyre with stiffer sidewall). Anyway, the end float of the hub was in spec when checked with a dial gauge. A tiny amount of movement can be felt in both hubs with cold bearings - is this normal?
