stephen290361
- Dec 22, 2011
- C250 TD 1998
Hi all
Not sure if anyone can help I had a leak from one of the pressure valves on my fuel injector pump after spending a couple of days locating the tool to take it of changed the the rubber and copper seals on all five valves ever since then the car has been running badly and heavy black smoke has been poring out the exhaust. I have had them of and on replacing valve housings and seals every time with little or no effect. The bosch inline pump is meant to be bullet proof and I can't see how I have damaged it by doing what I have done. I have spoken to mercedes - as I have ben there several time now and they say that i can't do any damage to the pump. I have listed some of the things I have tried;
1. Change all seals torque setting to 26lbft
2. Bled pipes up to injectors while running
3. Progressively torque down valves.
4. checked all valves while running to see if they are injecting on a regular bases.
The car was running fine before I have changed the pr-filter and main fuel filter + rocker cover seal and oil filter I can't see how I have effected any other part of the car. On the second attempt I have left the inlet manifold off don't think that would make any difference to the basic running.
I would take it to the garage but can't as it is running and smoking so bad I don't think I would make to the end of the street without being stopped.
Hope someone can help and apologies for going on so much.
Steve
Steve
