ali.shaikh22
- Dec 7, 2013
- C250 TD
Hello
I have a wonderful C250 TD that has been very reliable however last night on the motorway after about 150 miles of driving it felt like there was no power, or at least no assisted power from the turbo.
I could rev it up to around 1800-2000 mark and usually you can feel the car with a boost of power but last night and even today, nothing. I tried kick-down last night and sometimes the revs would jump to around 4000 mark but no real power and at times they wouldn't even go up as though the switch under the pedal was just not working. But you could feel it clicking.
Ive also been getting really bad MPG.
The car will rev up and i will get speed but it feels like its the engine doing all the work
Ive been reading up on the forum for similar issues and what ive found so far is that it could be the MAP sensor or the wastegate actuator on the turbo?
There are also suggestions that this would cause the car to go into Limp mode.
Also note, my glow plug light stays on for about a minute on initial start-up but then does go away and does not come back on
I intend to open the car up myself but can someone please confirm if I am on the right tracks, also, where are the MAP sensor and the turbo waste-gate located and does anybody have any replacement tips? write-ups?
Once I do open it up I want to clean the EGR valve and the rubber pipes, any suggestions on how to clean it?
Any ideas would be greatly appreciated.
Thank you
Thank you
