I have a 99 C250TD on which I'm doing a conversion to run it on vegetable oil.
I have a flat plate heat exchanger to fit in parallel with the heater matrix so that the it is permanantly fed by hot coolant, but with all the duo-valves etc I can't work out where to 'Tee' into the coolant system
On my old Vauxhall Cavalier it was easy as there were only 2 hoses to the heater matrix, IN & OUT!
I need to 'Tee' into smaller diameter pipes wherever possible.
Can anyone help with a description of how the coolant flows around this OM605 engine, or even a parts diagram so I can work out which hose goes to what?
Thanks,
Mark.
Thanks,
Mark.
