c270 cdi epc error only on kickdown
mbc270cdiscott
essex
c270 cdi
hi there iv just got this problem on my 2003 c270 cdi ,when you hit kickdown i get a epc light flash then go away ,so i dont get any kickdown power ,but if i put my foot down to the point just before kickdown button endless power ,
any help will be appreciated
many thanks scott
I would suspect the throttle potentiometer to be faulty (the small unit under the bonnet, nearside and close to the bulkhead, what the throttle cable connects to)
great thanks i will try that ,one thing i noticed is that when i put ignition position 2 so lights are on dash,then put my foot on throttle pedal and touch kickdown button same flash comes up without the engine on at all.
cheers panason1c i will try that
Definitely worth trying another potentiometer.....(throttle position sensor)
MERCEDES ML 270 CDI '03 W163 ACCELERATOR THROTTLE POSITION SENSOR A0125423317 | eBay
thanks mate changed throttle sensor iv got kickdown
happy man thank you again
