Hi All,
I am new to forums but I have a problem that I just don't have a clue what to do.
I have a 2002 c270 cdi W203 and is in constant limp mode.
When on diagnostics I get the following codes:
P0100 MAF sensor
P1403 egr Valve
P1470 Boost Pressure regulation
P1189 Inlet port shut off.
It first started off going into limp mode intermittently but has got to the point in which it is in permanent limp mode. (Just to let you know I only drove my MB about 50 miles before going into limp mode permanently) I believed that the problem was either the EGR Valve, the ECU (because the cooling fan is on all the time), inlet ports or the MAF sensor.
I have fitted a brand new MB manifold, 2 new Bosch MAF sensors and a new ECU all which have still left me with the same fault codes. I have tested the voltage going from the ECU to the MAF sensor and all seems ok. I believe that it has to be something electrical but I have no Idea where to go from here. I am sure someone has a greater knowledge than me in regards to this problem.
From looking at forum's the only other thing I can think of is it is something to do with the gearbox but I just cant get my head round why it would be the gearbox if when on diagnostics the MAF sensor is showing 0mg/stroke??
If you could help or even give me an idea on where to go from here please help.
Oh Since I changed the ECU i get the following fault messages on my dash, coolant level sensor, which I have a new one but has not been fitted and stall error message. I do not know if these are linked but I wanted to give as much information as possible.
I just have no idea...
P0100 MAF sensor
P1403 egr Valve
