C270 Nothing working... nothing!
Discussion in 'Electronics' started by estate-agent, May 8, 2019.
  1. estate-agent
    estate-agent Active Member
    119
    Aug 11, 2007
    Car:
    W203 270 CDI Wagon - previously CLK 320 CDI Sport
    Hi gang,
    Just a quick one, I've driven to work as normal in my 270CDI and as usual everything was normal, car turns over nice and fast in the mornings so nothing that has been even slightly odd. I spent 3 hours at work then came out to leave and I couldn't unlock car with remote key, I checked key and all looks good, red light flashes and using my phone camera I could see the infra-red light working too. So I used the solid key from the fob to get me in the car, the central locking didn't work but I suspect this may be normal from opening with the key in the drivers lock. Then I put the key in the inginition slot and usually the steering lock releases but this time nothing, not a damn sausage! I've tried to do a basic key reset / sync but nothing happens whatsoever. I had no tools on me at all so couldn't do much investigation but battery leads are on and tight and I don't appear to have left anything turned on in the car and to be honest I don't think anything that could be left on without the key in the ignition would flatten a perfectly healthy battery so quickly! Anyone experienced this kind of issue before? I walked home from work and will pop back with some tools and jump leads etc in a while but any input would be handy before I go back. Thanks all.
  2. whitenemesis
    whitenemesis MB Club Veteran
    16,404
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2019
    Alarm didn't go off?
  3. AMGeed
    AMGeed Hardcore MB Enthusiast
    12,813
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2014 E63 Biturbo
    As above. No alarm when the door was opened?
    Were there any courtesy lights when the door was opened?
    3 hrs is a very short time to drain the battery however. Hope you find the cause.
  4. Ted
    Ted MB Enthusiast
    5,731
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    I would be checking/cleaning/tightening the main battery connections.
    Time to get a test light or voltmeter out and start diagnosing.
  5. alecmascot
    alecmascot Active Member
    375
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    I have had batteries go completely open-circuit overnight!!
    m80 likes this.
  6. Major774
    Major774 MB Enthusiast
    1,870
    Sep 6, 2012
    Car:
    W211 E55 AMG
    As per Greenmanslk’s note.
    If you are not getting any steering unlocking sound then it could the EIS.
Share This Page
