Grantovski
Hi guys seen a C280 sport, looks tidy for the year. Any thoughts on what to look out for when buying one? Done 113,00. Miles.
Obviously cars of this era and mileage are starting to bubble and rust. Some more than others. So are you saying its not fixable? Or too expensive?
head gasket and timing chain cover need to be checked for any signs of oil leaks
Rust to boot lid near lock and check rear dog legs for rust as well as front wings
Front wiper, rust, head gasket leaks, check it pulls well with no hesitation or flat sports when accelerating, gear changes should be perfectly smooth with the engine warm. Make sure it's been serviced on a regular bases, then enjoy the ownership of a very nice car.
bedwards1966 said:I'd say it depends. My 1999 one is perfect underneath, the only rust was round the wheel arches, which was there when I bought the car 2 years ago. £250 got that done at a backstreet garage (would cost much more than that at most places though), and you can't tell it's been done. The odd bit of rust is starting to bubble up now (mainly due to the very harsh winter the year before last), perhaps in a year or so it'll cost me about £200. Not exactly major money, especially as it's not critical to the running of the car.
There is a thread on here about a C43 that had some serious rust issues, and will have cost a fortune to mend, you might want to have a look at it to give you an idea of where to look.
Here is the thread:
http://www.mbclub.co.uk/forums/mbclub-projects/135085-w202-rust-word-warning.html
Due to the age of these cars, the bodywork is never going to be perfect, but if it's not too major it can be fixed. It's the main thing to look at in a way, they're very good mechanically.
The oil filler cap and inner neck had slight signs of mush, the dipstick was clean though. No smoke out of the exhaust and no signs of the head leaking. Any ides? Is that common on the V6? Cheers guys
Will said:Not in the slightest, the M112 V6 is pretty much bulletproof in this respect.
ucr said:Your luck may be in ?
my car is 1996 and does not have any rust (first owner had it in a garage from new)
Would be nice if the C280 sport you are looking at has the AMG kit
Have a look under the car for signs of a wet diff. Diff seals on w202s tend to leak. God bargaining point and also ensure the car has two electronic keys....I think new ones are in excess of £100.
On the v6 engine, the oil seals on the oil cooler are prone to eventually leak but its a faily easy diy job to fix. It evenually lands up dripping on the fanbelt and it eventually shreds to pieces. When you go and have a look at the car, pull the plastic cover off the top of the engine and have a look for telltale signs.
