Hi, so I have a vibration/shudder at around 70 - 80mph in my car which I can feel through my seat, more than through the steering wheel. After inspection, it appears that the diff mounts are worn and have a bit of play and also the thick rubber bush which sits between the prop and the diff is cracking around the bolt holes.
Anyhow, I will replace these soon but I wanted to ask if there are any other parts which I should/could replace at the same time? And, if any one here has an idea of how hard/much labour it will take.
Thanks in advance,
Garry
Thanks in advance,
Garry
