dorifto_san
Hi Guys
Ive got a little issue with the dipstick on the C32. To check the transmission oil level does the drivers side intake manifold need to come off?
It seems that to access the dipstick tube - pull the cap off and insert the dipstick that the manifold/airbox has to come off as there aint enough clearance as it sits under it.
Is this correct?? Just concerned as i need to check the fluid level in the box and cannot have the engine running to do so.
