0ptic
- Dec 22, 2010
- Location
- Bristol, Avon, England
- 2002 C32 AMG, 1999 w202 C200 Esprit
Hi All
When I bought the C32 (from small independent garage) I asked that the autobox fluid and filter be replaced. They did this and apart from the torque converter lockup thing that everyone of these appears to have it's been OK. As the weather has got colder recently though, I have started to get a strange shift problem that clears after the first mile or two, I guess as the fluid warms up? It feels like the TC is locking and unlocking, or the box is changing up and down at low speed or light throttle. I had a gearbox dip stick I bought for my W202 (722.6 box also) and I dipped it today after taking it for a good warm up drive. The level is a good 1cm over full.
Two questions for the transmission gurus here. 1) Could this cause the problems I'm having? (why only when cold though), and 2) Any idea what else this could be a sign of if it's still the same once I get some of the fluid out?
I did try to put a small plastic tube down the dip stick tube to suck out the fluid today, but it wont get past one of the bends about a foot down the tube!! I guess I'll let the garage put it on the ramp and drain some from the bottom unless anyone has solved this little problem before. Would cold fluid aerate worse than warm if it's getting stired up by the gears?
Cheers
0ptic
Cheers
0ptic
