C32 Head Gasket?
callahan
North Essex
C36 AMG & C200 cdi (w204) - both gone, now a C32
Hi
I have been seeing quite a loss of coolant in my car (2003 estate) and did some digging around yesterday. All I can find is that the expansion tank was damp underneath, so it may be leaking through the cap when under pressure. However, I put over a litre in and it still wasn't quite up to the mark.
When there I did notice some oily deposits on the rear of the cylinders on the driver's side. Checking under the oil cap there was a tiny bit of 'mayonnaise' like reside, but it was tiny?
Obviously I have been dreading any issues with this car but knew it would only be a matter of time.
Any suggestions on what to look for etc?
AMGeed
Hardcore MB Enthusiast
Bournemouth/Poole Dorset
2014 E63 Biturbo
Check your water pump behind the belt. Often a failing pump starts with a very small leak that is hardly noticeable.
The mayonnaise like deposit inside the oil filler cap is quite common and usually points to condensation during the colder months.
A compression leak test is usually carried out to determine if the head gasket is leaking.
streethawk
leicester
E320cdi sport
Is the oil level rising? And if you smell the oil you can normally smell antifreeze in it if it's that bad. Could just be the cap that's had it.
OP
OP
C
callahan
North Essex
Thanks, I'll take a look tonight. The mayonnaise was very minor, so hopefully not too serious. The car had been idle for two weeks but had the dreaded 'check coolant level' message when I started it up again.
AMGeed
2014 E63 Biturbo
Take the car for a run to warm up the coolant then stop the engine and feel with your fingers if there is any coolant weeping from the pump.
Hopefully that, or faulty coolant filler cap is your problem and not the dreaded HG.
OP
OP
C
callahan
North Essex
I did want to check the level, but with no dipstick it makes it tricky.
When I try through the display I get 'perf serv on time' which might be because I had the engine running to get the car to a flat surface. Will try later.
The oil in the cylinder is pretty black, so I was thinking of changing it anyway - I'll have sniff later!
OP
OP
C
callahan
North Essex
Just noticed that while moving it off the (gravel) drive to get it level to check the oil, I left a trail. Hard to tell what this is, but possibly coolant. There is a damp patch at the bottom of the off side front wheel well, but I can't see anything else dripping now.
The gravel makes it hard to tell if there are any leaks - I would leave it on the road but I think someone has gone on holiday and left their car in front of my house, a black polo hasn't moved for 10 days!
Gaz74
Herts
C32 AMG
See if you can lay a piece of cardboard under it, and if it has wet patches (oo-er) then you know you're leaking from somewhere and a better idea of which side of the engine bay.
OP
OP
C
callahan
North Essex
Glad I wasn't the only one who thought that when I wrote 'damp patch'!
Good idea though, thanks.
AMGeed
2014 E63 Biturbo
That is where the AC drips after being turned on in warm weather. That could also be where you have coolant leaking as well:dk:
Gaz74
Herts
C32 AMG
Isn't that also the location of the intercooler pump? Or it's just where the leaking coolant is gathering..
OP
OP
C
callahan
North Essex
I thought the intercooler pump might be there too, which worries me slightly.
I'll try a few things tonight and report back.
RyanMuller
C32 AMG
Off side front wheel area is where the intercooler pump is, check all the clamps?
I was losing coolant when the charge cooler packed in, had to top up every 2 weeks with coolant but I didn't have wet patches under the car - sound's like yours is coming from somewhere else.
Would be interested to know once you find out.
AMGeed
2014 E63 Biturbo
Sorry, I misread the first quote thinking n/s wheel well:doh:. As mentioned later, ic pump sits there.
OP
OP
C
callahan
North Essex
Just as an update, I am keeping an eye on the car for now and will add to the thread if I find anything.
