Neil Mackay
- Nov 17, 2011
- C32 AMG Estate
As title, just fitted the Needswings Intercooler fluid Isolation kit to my C32. Took about 30 mins of faffing about, and the cars only gone through one heat cycle so too early to turn the valves off (needs to let air out first)! Once the two valves are turned off (one supplied with pipe, the other just a valve that needs to be cut into the OEM pipe) they isolate the Charge cooler system from the engine coolant system. The car is due to have the charge cooler pump replace in a week or so too so ill do some data logging, before the system is isolated, after the system is isolated, and then after the charge cooler pump is replaced! See if its as cracked up as our friends over the pond say it is!
