John_Doe
- May 5, 2011
- C32
Afternoon all,
I have had this random engine misfire for a while now and it's been too several indy garages and even main dealer. All they tell me is that it's misfiring on cylinders 1 and 6. They recommend changing plugs, leads and coil pack. I can get the same bloody info off a silly little OBD 2 reader!
The car will run fine for a while and then it will kick up the engine light and go into limp mode. So reset the system and it goes away.
Anyway I thought I would start by fitting new plugs to cylinder 1, and swapping leads and coil pack between 1 and 4. Obviously had to be 1 and 4 because the leads are different for each cylinder but either side match. I ran the car and the same thing happens again. Still on cylinder 1 and 6. So that tells me it's not plugs, leads or coil.
Where do I go next considering garages are really not helpful with this.
I should also note that I am losing coolant :-(. I started thinking head gasket but I do not have any other signs of HG failure. It doesn't over heat, no cream in oil and if it failed between cylinders surely it would be between cylinders that are side by side, not at different corners. The coolant leak appears to be leaking onto the floor while parked and not being drank by the engine, however it does smell a little exhaust / oily
Oh and! If I put my heater on with the windows up I will pass out from the smell of burning oil/ fuel / exhaust fumes! Any idea what that is about. Why would I get an exhaust smell through my air vents?
