I mentioned this on another related post but thought I would start a separate thread.
As the title states, only if I put my foot down and have the sunroof open can I smell the fumes.
I have noticed what I assume is exhaust exiting around the turbo, difficult to see in the pic but alot of black soot around the linkage - is this normal ?
I was told due to the staining it has probably always done this.
I was also told I had 2 X leaking injector seals and 1 possible bad injector. - On inspection from another indy, all 6 are clean and bone dry - does this mean they are ok ??
There is some gunky mess under the right side air intake and around the air inlet to the turbo seal - this might be old as the recently replaced intake manifold still looks clean - you would think there would be dirty finger marks in that area though ?
This was done at the same time the oil cooler seals were replaced so everything was out..
