Yep even when engine is cold, good shout cos I tries the air con last week and it wasnt cold at all, might get it re gassed see if that fixes itIs this even when the car engine and coolant temperature is low. If so, it could be low air con pressure. I've just had this. I'm waiting for an air con pipe, as whilst it was the condenser that had a leak, the short pipe that connects between the compressor and the bottom of the condenser had welded itself on with corrosion. Even leaving the bolt soaked over night with penetrating fluid (not WD40), I ended up (very easily) snapping the head off the bolt. Such a pain.
Now FedEx have lost the pipe which was sent by Mercedes Grangemouth last week.
