Ferg
Map from your ecu is extracted by obd2 or directly from the ecu dependent on whether the ATP (anti tampering protection) has been cracked or not. This is then loaded onto a laptop with tuning software that decodes the data into maps that affect the various running characteristics of the engine and throttle. With a basic remap on a diesel you can get away with light - medium increase of fuelling, boost, smoke and throttle sensitivity without live mapping. Live monitoting will be of benefit if you are going for the last 10-20% where you need to make sure you're not pushing egt too high etc.
Not strictly true, last 10 years or so Mercedes via ODB is normally id only, the company doing the file will have a file already based on your Car and ECU type Etc, this file is modified and uploaded to your car, you cannot extract a full read of a Mercedes ECU Via ODB, just the basic information ie type and vin, hence why you see persons on the net offering cheap remaps and full reads, and try to load a manual map on an Auto car as one example, 1) because they don't have a database of the correct tuning files, 2) don't know what they are doing but will take your money anyway. Anyone offering a full read on a Mercedes via ODB stay well clear
