This is debatable. Personally I always send the head off for a pressure test and clean. I also ask them to check the head for being straight and true. Total cost............£36. To me it makes sense to send it away.Do you think it would be possible to change the head gasket without having the head skimmed? As it has never over heated and the coolant and oil haven't mixed and this would make the job much cheaper and easier for me to get done.
Make sure you get the right headgasket. You need an AMG one and not the 320 one...what other parts will I need to get to complete the job?
Do you always change the bolts? I measured mine and they were well with spec so I re-used them....Head bolts.
skim and gasket change for £115. He must work for peanuts as its an 8 hour job. A Mercedes gasket alone is going to cost in the region of £50.When I put my C36 engine into my 190 , I got the HG done at a place in Harringey , price including skim and gasket was £115 .
