C36 Misfire/rough idle advice please.
Discussion in 'Engine' started by cazyp, Jul 4, 2011.
  1. cazyp
    cazyp Active Member
    266
    Oct 23, 2010
    Car:
    C43, Hilux
    Just recently the C36 has developed a slight misfire - more noticable on idle than when driving. The rev needle fluctuates just a tiny amount - about 100 to 200 rpm.
    It is worse on warm starting - although the car starts fine - it idles rougher when warm.
    No fault codes showing.
    I'm going to change the spark plugs but any ideas where to look then? Don't want to go down the route of random replacements of parts if I can help it.
    Many thanks.
    On a side note on the MOT - which it passed - it only just came down below the CO2 limit. Could this be related? o2 sensor?
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,922
    Feb 8, 2007
    Portsmouth, Hampshire.
    Car:
    E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
    Fault codes don't mean much in this case. The live data needs to be checked. Plug into a star and have a look at the smooth engine running menu. This will guide you to what cylinder could be missing.
    Also check the maf and llambda values to make sure they are ok.
  3. horgantrevor
    horgantrevor MB Enthusiast
    1,902
    Jan 14, 2011
    Car:
    w202 c43 & w210 E220 CDI estate w219 W221
    what millage has it on her
    check fuel pressure at the fuel rail and clean the fuel rail filter
    leave the star test running when you do this also check the oxygen sensor when the engine is running the reading should be moving up and down
    i had this on my c36 turned out to be a faulty injector
    if you have a spare maf swap and check
    also i know the car can take three types of plugs as it says on the sticker under bonnet
    but the bosch always worked best for me not the champion or breu
    check ht leads for wear and also dont move the wire harness to much as could become brittle with age and you could cause more trouble
    keep us posted
  4. OP
    OP
    cazyp
    cazyp Active Member
    266
    Oct 23, 2010
    Car:
    C43, Hilux
    I checked all the vacuum pipes - one was loose at the front - seems to have dome the trick!:thumb:
Share This Page
