janner
- Oct 13, 2003
- E320 Turbo Technics
This guide might help with getting the head off...
PeachPartsWiki: Head Gasket Replacement
What a mess.
Line up the cams and mark the chain before you remove it. It's easy to put the chain back on the wrong cog if you don't.
do you see that air filter box next to you in pic left side just pull up a few times and the whole things comes out for more room its held in by three rubber bushes that its sitting on
keep us posted
Has that engine had a blow gasket for some time, or been left standing? I'm surprised at the amount of rust on the cam lobes.
I would look to replace the bottom end bearing shells as Glycol/water/oil mix makes an excellent acid which attacks them ferociously.
Yep - a small slide hammer and quality threaded bolt will make life much easier for the guide rail pin.
I wasn't comfortable trying to extract the pins on the MB engines I worked on with improvised pullers. The slight percussive 'shock' from the slide hammer will drift the pins out more easily and safely IMHO
Will
Looking at the inlet manifold, it looks like I'll have to leave it attached to the head because I don't want to risk rounding any more allen bolts.
Ideally you'll need an engine crane to lift off the head.
if you need bits let me know i have a m104 engine here that im breaking
so if you damage a manfold or round bolts i may be able to send you over good second hand ones if i can get at them
The full up retail price from MBUK by a MB dealer is about £80/£90
Best to get here as you will have MBUK part warranty on it
