C43 advice needed please.
MOUDIS C43 AMG
HI, was out for a drive and decided to use some amg power switched to sport and really went for it in the first two gears, when i came to a stop i could smell burning gear oil, light haze coming from the gearbox area needless to say it got me pretty worried.
it selects all gears fine ,i've checked underneath no obvious leaks.
can anyone suggest a specalist in manchester to give it a once over.
There are two garages in Manchester I would recomend. I used to go to Greenvale Services in Whitefield which are good. Another member of the forum I directed there a while back had a problem solved.
I do however use a guy closer to me now which I rate highly. Jason at Benz tech in Golborne. Not sure if you can receive PMs but if you want I can provide you with contact details for both.
Try Andy at AutoBarn, near Chester (Just off the M53) CH66 9PA, 0151 347 9999/07914 805586. He was with Mercedes for 16 years and owns a C43 of his own. Great guy and a true Mercedes enthusiast who really knows his stuff.
I second that recommendation. :cool: A thoroughly decent and honest chap.
THANKS, could please give me some contact details.
You can ring Jason on 07813 621969. He is located just off the east lancs road A580, turn at the golborne roundabout. Go past golborne town centre and at a mini roundabout turn left into the business park. In terms of Greenvale they are on 0161 796 2666 and if you google the name you ll fond the address. Hope it's nothing serious and you get it sorted soon.
thanks for the info time to make some calls and spend some money.
thanks ,will let you the outcome hopefully not to much of a big hi.
