when i drive my c43 and car gets proper work temperature between 80-90 degrees Celsius on coolant after a long drive, this is the correct work temp not to worry about.
i have added 3x extra VDO gauges to my console where i previously had the a$$tray, like in the 16V Cosworth car now showing me: oil pressure - oil temperature - volt meter.
i have also fitted a brand new MB BEHR radiator to my engine.
now to my question?
coolant temp reads 80-90 degrees Celsius on my cluster after fully warmed up drive.
my x-tra fitted VDO oil temp gauge always reads and stays between 80-85 degrees Celsius on oil temperature after a hard drive, should this oil temperature be OK after fully warmed up or should oil temp rise higher?
this is the gauge i have
VDO Viewline Ölthermometer / Öltemperaturanzeige (126.736/126.807) | eBay
now to my question?
