converse120
I am pretty sure my C43 is down on power and generally not performing as it should – it doesn’t accelerate as well as I think it should, seems to get confused on kickdown and also hesitates between 3000 & 4000 rpm when accelerating. When I had it serviced recently (60000 mile) it was showing a fault code for the MAS/MAF, and that together with the symptoms I’ve read about on here would seem to point to it being the MAS that’s at fault. I don’t think it’s just familiarity, as I’ve found myself stranded on the wrong side of the road a few times when trying to overtake much less powerful cars, having previously been able to sail past.
However, it flew through its MOT today, and my friendly local (non-merc specialist) mobile mechanic who took it there for me said that the emissions wouldn’t be correct if the MAS had gone, yet it had great results on the emissions test.
Before I shell out £80 on ebay for a replacement (which I can ill afford atm), can anyone shed any light on this, or suggest other possible causes of the aforementioned symptoms ?
Many Thanks
Ian
Many Thanks
Ian
